satoer
2016-12-27 20:45:25
I’ve got a few questions regarding Midi translator. I’m running the trial version to test it. It seems to work, but I can’t find some options I really need to make this program usefull.
1: Activate a preset when an application is in the foreground.
I want to translate midi messages from a midi controller to keypresses. But I want to control several programs. And some programs have a native support for the controller. I want the preset only active when a program is active / has focus. Otherwise the presets will intervene with each other. Is this possible without having manually activate / deactivate the preset?
2: Macro’s:
I want to create keyboard macro’s. So several keypresses after each other with the option for a timed delay between the keypresses. I see some “Apple script” option, but I work on windows so that’s not an option.
Or are these options already possible and have I overlooked them?
Cheers Michel.
2: Macro’s:
Cheers Michel.
