capital letters using keystroke out
b52productions
2017-01-01 06:49:25
having problem in trial pro version, i cant get shiftQ or shift q etc
works fine in the classic version any suggestions?
dont feel like paying for full version if its not proper,
i have tried with space and without, tried as a text out also.
windows 7 64bitand run as admin.... thanks
Max Oepen
2017-01-02 03:31:24
I can confirm that the Pro version works perfectly in this regard, and projects from previous versions work without any problems.
You'll have to explain the problem you're having more precisely:
What does "I can't get" mean in this context?
- It's not registering the keystrokes as you enter them into the "Incoming" / "Outgoing" text field(s)?
- It's not outputting any keystrokes/text when triggered?
- You're not getting it to display "shiftQ or shift q" [sic]?
IMO the Pro version is worth every penny and then some.
Max Oepen
2017-01-02 03:34:35
If I had to guess, your problem is that in "Outgoing" > "Keystroke" you have the "Text" radio button (default) enabled.
That way Shift + Q will display as "Q" (the actual output), not "Shift(Q)" (physical key output).
The output (as far as text) is the same.
If you switch it to "Physical Keys" it will behave as it did in the previous versions of MT.
b52productions
2017-01-02 05:46:20
first of all thanks for the reply,, yes i have tried "physical keys" output but it only triggers lower case and not upper case as the classic version works just fine, any other suggestions?
2017-01-30 06:45:17
Hi, sorry for the late reply.
Another guess what could be happening: if you run MT as Admin, you can only send keystrokes to other programs running as admin, and vice versa. In general, we advise to never run anything as admin...
