PRKid
2017-01-04 08:45:48
Hi!
I have just started diving into the BOME MIDI Translator and was hoping to get some feedback on whether or not I am structuring my first "test" project for my learning curve. I have several controllers that I would like to map to Pioneer's Rekordbox software using Bome. Rekordbox's current midi implementation has many limitations, thus, the need for add'l external support. My practice run is with the simple Numark DJ2GO controller and I am currently focusing on the LED ON/OFF controls.
I have been able to turn the LEDs ON, yet they stay ON, or, I can turn then ON/OFF during one press of a pad. Yet, I want to be able to keep the LED ON when the first press (2 Note commands) the pad, then, turn the LED to OFF when I press the pad again and so forth. The controller has 4 functions per track (A and B) with LED feedback (CUE, SYNC, Play/Pause, and, Headphones/PFL). So, for the LED control section of my project, I've created 1 Preset (LED Controls) along with 16 Translators (4 functions x 2 tracks x 2 [On/Off]). Yet, I feel this can (and should) be simplified, yet, for now I just want to make sure it works within the logic of the Translators along with the Rules. I have tried various combinations of rules for the Note On and Note Off messages, yet, none appear to do what I'd like.
What rules are best suited to address this problem?
Attached is the current file which I've been editing.
Thank you in advance for the feedback.
Test No3.bmtp
Test No3.bmtp
