PRKid
2017-01-05 08:23:42
After pulling together all the mapping of the pads/faders/wheels, these seem to be working correctly between the controller and Bome and I can see the proper triggers using midi monitor and Bome's log. Yet, when I connect it to Rekordbox and pick Bome as the midi interface, no action occurs on Rekordbox (wheels/faders/pads). I tired changing the ports to ensure that was not the issue (though it still could be per what I've chosen), yet, not successful.
The 2nd issue is that of having the 4 pads (Cue/Play/Sync/Headphones) to serve as both LED triggers, as well as, trigger their particular function. For this I set a separate Preset (#2, Button Controls), yet, had to deactivate it since now my LEDs were not toggling (they were staying On).
Attached is the current work-in-process file. Any pointers to get both of this 2 issues corrected and/or ideas to test are welcome. Thank you!
- Attachments
- Numark DJ2GO.bmtp
- (13.17 KiB) Downloaded 349 times
