PRKid
2017-01-12 01:35:51
I am sure the Subject description is a little confusing, yet, let me explain. I am using the Traktor Kontrol F1 and would like to select the deck I am playing by switching these via the bottom 4 pads. So, I want 2 functions to be served.
(1) If I turn On/Off Deck 1 (enabled via pad 2) by pressing such pad (this is the easy part and works fine for all 4 pad/Decks). Once On, I assign the "ka" variable to the Deck # to keep track of the Deck that is On.
(2) Now, the 2nd functionality is, when a Deck is On (say Deck 1/pad 2) and I press to select another Deck/pad (say Deck 2/pad 3), I want to send an Outgoing message to turn Off the Deck's LED of the one that is ON (Deck 1). This gets very confusing once I want to enable such for all 4 pads/Decks, especially keeping track of the variables and toggle functions.
** Channel 13, CC#'s 37-40 (Decks 3/1/2/4) on pads. Used "ga/gb/gc/gd" to toggle, and, used velocities of "oo/pp/qq/rr" for decks 3/1/2/4 respectively. I tried unsuccessfully adding another Translator (variables of "gv" for toggle velocity "hv") to turn off the the On Deck once I press another one, yet, then they all go to the "On" mode. Read thru all the threads on LEDs yet did not find something similar.
I can do it with 2 Decks, yet, cannot do such beyond that.
Any ideas? Anyone wanting to tackle a little challenge?
Thanks in advance for any thoughts.
