CHudson
2006-03-03 04:12:41
So I want to use MT to convert my CC7 volume pedal to CC11 Expression data. I set the input of MT to my hardware midi in and the out to midiox port 1. In the Incoming tab. I used the "capture midi" box and moved my volume pedal. It recorded the data as "B0 07 oo"
On the outgoing tab, I did the same prcoess , but manually changed the 07 to 11. I saved the preset . Opened up Kontakt and set the midi in to midiox port 1.
Nothing works
also, the cc7 data is still getting through as when I adjust the volume pedal, the volume control changes on the sampler.
Any ideas on where to go from here?
CH
Nothing works
CH
