I'm using m-tron by Gmedia, and for some reason, it uses CC95 for pitch bend. What I would like to do is translate pitch wheel messages to CC95. It looks like I can probably do this with MT. Has anyone else done this, or do you know how it could be done? Do I need midiyoke?
Thanks-
John Blattenbauer.
2006-03-07 22:25:19
yes, that should be quite easy. Install Midi Yoke. Then, in Midi Translator, set up a translator like this:
Incoming MIDI: E0 oo pp
Outgoing MIDI: B0 5F pp
In the main window, choose
MIDI IN: the hardware MIDI port
MIDI OUT: Yoke 1
Options|MidiThru: yes
In the program where you use m-tron, choose Yoke 1 as MIDI Input.
Hope that it'll work!
jendask
2007-01-17 21:03:56
I've done the same thing in order to use pitch wheel of my midi keyboard along with M tron but now I can no longer use it with another vsti (Pro53)!
Any ideas?
I mean is it possible somehow that the movement of thhe pitch wheel can "talk" to either Mtron or Pro53 ( the one that is currently activated)?
2007-01-20 04:54:12
You mean you want the original pitch bend message to be let through, too? No problem, just check the option "Output both translated action and incoming message" in the "Outgoing [F8]" tab. And, as said above, enable MIDI Thru in the options.
jendask
2007-01-20 19:06:53
You are my man!
Thanks again
Greetings from Greece
