zeze
2006-03-18 00:28:26
Hello 1st off
and i would like to say what a great prog midi translator is. It has solved alot of problems for me. but there is just one thing missing IMO........
I would like the ability to choose the midi port that the midi thru sends its data to.. So the midi out acts like an auto thru to whichever port is selected, and you can choose a different out put for the midi thru
I.e
Midi in = sound card
Midi out = midi yoke 1 (goes straight to the output port, without haveing to check midi thru)
Midi thru = midi yoke 2
I would REALLY appreciate it if you could add this feature
zeze
I.e
zeze
