Peter Nicholson 2
2007-04-05 21:51:23
Hello Florian
I am currently trying to code a translator, in which I want to input a number from 0 to 999.
I can’t use numbers 1 to 0, or Num 1 to Num0, since they are being used already in the, eventual, same preset.
However, I have no ideas, at present, on how to go about this.
I eventually want to output this number as part of an outgoing key-press string.
Your help with this problem would be greatly appreciated.
Also, on 02/04/2007, I placed a posting on the Midi Translator forum. Although I viewed it on the forum the same evening, it has since disappeared!
Have I fallen foul of the forum rules somehow?
So glad I purchased MT Pro, great programme.
Also, I was looking through the forum for hints, tips and “clues”, and in particular, at your exchanges with Lowrenzo, which I found most useful. However, I didn’t understand your posting to Lowrenzo dated 11th January 2007, relating to midi volume Up/Down. The precise bit I didn’t understand was the variable gv in the Outgoing: Midi BO 07 gv, where gv appears to be Decimal and not Hex.
As a beginner with MTP, I thought that the midi message should be entirely Hex, but perhaps I have missed the point somewhere?
I would be grateful for your advice on this.
Regards
Peter
Regards
Peter
