Kristian
2007-04-09 17:54:18
I'm trying to set up one of the pads on my Korg Padkontrol to open and close Ableton Live's browser. The key command for this is ctrl+alt+b.
In Bome's, I've set the correct input (I'm sure it's correct, since "capture MIDI worked)
As MIDI Out, I've set MIDI Yoke nt 1 (not sure if this is correct, but it's what seemed most logical)
The pad is sending out a note value with fixed velocity set to 100
In Ableton Live, I've activated all the inputs and outputs available, as my MIDI knowledge is fairly basic/limited
Still, with all of this done, nothing happens. What am I doing wrong?
