slash studios
2007-04-13 06:33:32
I looked at your program and I have to admit that it looks like it has promise. I however can not know for sure because it doesn’t work with macs
. So here are my three ideas.
1. Make it mac compatible
2. Create an interface to translate mtc, sysex and midi control commands into hui! For example you assign the midi interface to b.m.t. , Then the out of b.m.t go to the software and vise versa. The idea then is in b.m.t can assign certain incoming commands into certain outgoing commands. ...
like this
midi controler sends out command 7 on track 9 value 127 into b.m.t. then changes that into hui:
1st track of 2nd back is at 100% volume
or another usage
the tascam dm 24 sends out a sysex messge when ever the record button is hit, so you can program that command in to b.m.t. And translate it into the record command for hui.
My last idea is find a way to make this a vst or some sort of plug in for recording software, that way u can have a sequencer lunch commands.
(Sorry if their is something similar to that last one as I said I’m on a mac, I haven't really got to play around with this yet.)
thanks let me know what you think
like this
or another usage
