Razvan
2006-04-21 14:36:59
i what to make something like Kid Beyond but instead to use foot panel i whanna use num pad keys
is this posible and how to configure MT ?
Tank You !
Tank You !
Razvan
2006-04-21 14:36:59
2006-04-22 09:34:09
chelfyn
2007-03-30 13:52:48
here's the ableton project, and here's a picture with all the info you need. pay careful attention to the IO assignments and the fact that 1-8 are permanantly armed. It's not 'monophonic' like the MTPro controlled rig, so you have to turn off recording on each channel, but in operation, you start by hitting '1', then stop by hitting '1' again. if instead you'd wanted yto continue on track 2, you'd have hit '1' and '2' together. not quite as smart, and not automixdown goody on channel8, but not bad for an ableton only solution.Razvan wrote:i what to make something like Kid Beyond but instead to use foot panel i whanna use num pad keys
Tank You !
