Multiple Instances of MT and Key commands
Richard Soup
2007-05-05 14:28:59
Hi - I use three different controllers live and after I read a previous post on this forum set up a second instance of Bome.
This was OK - until I tried using keyboard input.
I was setting up a variable depending on which number was pressed.
I wanted to use this setting in both instances of MT.
I realised that I waould have to set up a variable for each MT.
But only one MT would allow Key imput.
I even tried copying the whole Bome folder.
Any help greatly appreciated. - Otherwise I will have to use several extra Midi leads a MIDI merge box and 2 extra power supplies live - Which I would rather not do.
Best
Richard
2007-05-07 15:20:30
Hi Richard,
indeed: currently, key input is only possible in one instance of MT, and I cannot think of an elegant solution to your problem. It is easy to add multi-instance support, but we're very busy right now. We do offer the "feature rush service", though: http://www.bome.com/forums/viewtopic.php?t=178
Oh, and a future version of MT Pro will have support for multiple MIDI ports in one instance of MT, that would probably solve the problem, too...
Max Oepen
2008-05-20 11:00:46
Hey Florian,
I wanted to bring this thread back to see what the progress was on this feature or if it was even still feasible to include it in future updates. I still have a high interest in this option, and it's a central issue for me.
Creating separate instances and saving separate files for each external controller instantly makes my projects a lot more complex, especially if they sit for a few months and I have to come back and try to remember everything... :)
Max.
Tuur
2008-05-20 19:49:59
Max Oepen
2008-05-21 02:57:21
Tuur, thank you for the link!
Florian, I am in exactly the same situation as some others who use multiple controllers and purchased the pro-version.
Am I eligible for the multi-port beta?
Please say yes :-)
If so, do I have to upgrade to v.1.6.0 first or could I upgrade to the beta?
(I'm currently still on v.1.50 build 615)
Max.
2008-05-21 10:35:47
I Max,
the beta is self-contained, you do not need any other version installed, and you can also install it side-by-side with other MT versions.
