drob
2007-06-01 19:03:18
On a bcr2000 you have encoders (knobs) that shows Led when you move them. In Ableton Live 6, I have assigned one knob to control the volume of a track, but I also use Blue Cat Peak Meter VST on that track to show the movements of the volume signal (like a dj mixer). I have assigned the same bcr's CC# to both the volume control and the out meter(blue cat). That's fine except that when you move the knob to raise the volume Ableton assigns the value of the meter to the volume, which translates to sometimes volume jumps, which I want to avoid.
The VST has another button called bypass (can also be assigned a midi or key stroke). If bypass is on, the the VST is disable and it doesn't send midi info to the volume track. What I want to do is when I move up or down the knob, I want the bypass to be ON and as soon as I release it, OFF. This probably entails to have a seperate midi message for the bypass and the meter, but the bypass can't follow the same behavior as the meter or volume midi CC#.I've tried a few things, but my knowlledge with MT is very limited. I've scanned the forum for something similar and I didn'f find anything.
By the way I'm using MT Pro.
Thanks[[/b][/i][/u]
Thanks[[/b][/i][/u]
