nikozz2000
2007-07-11 13:59:38
Hi Florian,
I’ve just downloaded your program and it's really great !
I need it because Guitar Rig only sees 4 of the 11 Podxt's switches, so it was kind of scary to use without Midi Translator. Those 4 switches only worked when pressed twice.
So now, I'm working on doing a MT preset to control Guitar Rig with the Podxt Live.
So far, I've managed to make 9 (plus the wah pedal and the wah switch)of the 11 available switches to work, that's a big improvement!!
I Had to use midiyoke to make it work.
Press twice problem was resolved by your solution posted on the Art x-15 post :
I'll post the preset once it's done if it can helps anyone.
Thanks again
Nico from Belgium
(I’ll send you a postcard soon !)
What a great trick ! (I don't have a clue what's those numbers means but I did a copy'n paste, changing valuesIncoming: B0 4F pp
Outgoing: B0 4F 7F B0 4F 00
Then you don't need a second Translator Entry.
Thanks again
Nico from Belgium
