yes, you can do that.
In theory, you can do
transposition with the Classic edition of Midi Translator. However, it only allows
static translations, so you'll end up defining one translation for every note:
INPUT OUTPUT
NOTE ON key 20 -> NOTE ON key 32
NOTE ON key 21 -> NOTE ON key 33
NOTE ON key 80 -> NOTE ON key 92
The note numbers are in semitones, so adding twelve semitones will increase the note by one octave.
Midi Translator Pro offers an elegant way for doing so, by way of
"Rules" with variables (variables have 2-letter names, e.g. pp, qq, etc. or "global" variables ga, gb, gc,...).
Here, the octave transposition is one simple translator:
INPUT: NOTE ON key "pp"
RULE: pp=pp+12
OUTPUT: NOTE ON key "pp"
It'll be easy to change this definition to an arbitrary transposition, simply change the rule.
