Thom
2007-08-24 16:40:57
Hi, I've got a drum pad controller that outputs a note on when a pad is hit, and then follows with a note off. The time between the note on and off is very short and causing inconsistent responses in the sound source I am triggering. As a solution I wanted to delay the note off event with a set value of my choosing.
I think I have successfully set up a test preset in Bome MT Pro that will respond to a key stroke by sending a note on and trigger a delay which then triggers a corresponding note off.
There seems to be a problem however, when more than one note on is received before the delay has triggered the note off it causes hung note on's. Is there some way of preventing these hung notes from occuring?
Many thanks!
Many thanks!
