Hello...Question about Slicing programs
donny
2007-10-01 14:26:10
Thank you for the creation of this wonderful tool...
However, i'm curious to know if i would be able to use my M Audio trigger Finer drum pad's knobs to control the movement/placement of slice markers in my slicing program *Zero X Beatcreator*
there are no midi options for it, and to my knowledge the only mouse-free command i can use to control the movement of the markers are "ALT+left, or ALT+right".
I'm trying to recreate the MPC feel of chopping audio and i've yet to discover any programs that support what i'm trying to do..
So, will i be able to assign the alt functions to a knob on my triger finger?
2007-10-02 20:26:43
Hi Donny,
yes, you should be able to create Translator Entries following this scheme:
Incoming: MIDI message
(use "Capture" to get the correct MIDI message from the Trigger finger)
Outgoing: Keystroke: Alt+left
In MT's MIDI IN menu, select the trigger finger. Then switch to the Beatcreator software and try...
Just try yourself! The classic version will be fine for this.
donny
2007-10-02 23:24:07
Wow, thaanksss!!!!!!
Wow!
