schismatic
		2007-10-03 00:03:02
	I would like to be able to use two different keyboard keys to increase and decrease the volume of a track i have in ableton live. Because I do not have a midi controller with any dials/knobs or sliders, I am wondering if there is a way I can simulate turning up the volume by holding down a certain key so that while i'm holding it down, the volume will increase, and it will stop increasing when i release it. I want the same functionality for turning the volume down with another key. Is this sort of thing possible at all?
		2007-10-03 09:59:45
yes, this is possible with Midi Translator Pro: use "Keystroke" as incoming trigger. Use MIDI as Outgoing Action, entering the MIDI message for setting the track level.
Now a problem is that you want to convert individual key presses to an absolute volume level.
For that, use MT Pro's Rules: use a global variable e.g. gv to store the current volume. Each time you press the "volume up" key, increase gv with this rule:
gv=gv+1
Now you must make sure that gv does not exceed MIDI's range of 0..127, so add this check:
IF gv > 127 THEN gv=127
For lowering the volume, use these rules:
gv=gv-1
IF gv<0 THEN gv=0
For both Translator entries, use gv in the MIDI message as value. E.g. if MIDI controller 7 is used for setting the volume, use the following message in the Outgoing MIDI field for controlling the track volume with value gv:
  B0 07 gv
Enter this for both the "increase volume" Translator entry, and the "decrease volume entry".
Hope this explains some...
		schismatic
		2007-10-03 12:29:31
	thanks for the reply. I am new to midi translator, i have managed to set it up fine but I am not sure how to assign it to stuff in ableton. e.g. i have chosen 'Q' to be the key to increase volume. I followed your instructions to set it up in MT Pro but I am not sure what I should be assigning and to where in ableton. I tried assigning Q to the volume of hte track but all this does is change the volume from fully on to fully off, it is not progressive like I wish.
		2007-10-09 23:34:51
	sorry I don't know further from here. Maybe ask in an Ableton board?
