Max Oepen
2007-10-12 10:55:48
Hi there.
seems that MT Pro translates Hex versions of notes an octave higher in its description.
Why is that??
for example:
If I enter: 99 2A oo (2A representing Midi note# 42 = F#1), MT Pro describes it as "F#2"!
This only seems to be an issue with the description though, since it still receives/ sends the correct event. So, if I set the above (99 2A oo) as the outgoing Midi message, it does in fact send out on F#1.
Since the description does not correspond to the note played, this can get confusing.
Please comment.
Max.
Why is that??
for example:
Please comment.
Max.
