matsimpson
2007-10-31 20:57:36
Just started using MT, its a wonderful piece of software
I've started setting up some mouseless control style scripts, using keys on my BCR2000 to click left and right- this is fine. However, I want to make it so that if i turn a knob to the left (anti clockwise), MT will send a keystroke "Left", and if i turn it to the right, MT will send a keystroke to the right. This would make the script much less space consuming - halving the number of keys i would need to scroll up down left and right.. Is there any way of doing this?
i was thinking if you could put "*midi CC name* value goes up then that means scroll to the right, if the value goes down then scroll to the left. But i dont know how to do this if its possible.
Any ideas?
Any ideas?
