donny
2007-11-27 17:12:06
Hello, i was wondering if theres a direct input plugin or something that can be used alongside midi translator for certain applications that wont intercept directional assignments attributed to midi parameters.
for example "In Zero X beatcreator, i can assign the left+right arrow functions to two pads on my drum pad, and they'll only work if i'm navigating through the menu bar.. ie.. file, edit, preferences, etc.... when the true intent of the assignment is to switch between slice markers"
I believe you were working on something Florian, but i'm curious to know if any other people have found a way around this because the left and right functions are the only reason why i still have to use my keyboard..
Florian, is there a Beta for this direct input driver?
