Bryan
2007-12-07 21:52:29
I e-mailed you, but will post here as well.
"Start minimized" no longer works.
"Rescan MIDI devices" doesn't detect my USB MIDI keyboard. I still need to quit MIDI Translator and restart.
2007-12-08 00:42:37
Hi Bryan,
thanks for the bug report. The Start Minimzed bug is known (and already fixed in the development version). We'll check out the Rescan MIDI devices issue (normally, new MIDI devices should be detected automatically anyway...).
the bob campbell
2007-12-13 16:40:06
I'm finding an issue with 1.6 when it's running in the tray and you shut down Windows XP. Translator crashes ungracefully instead of shutting down quietly. I can post the message if required. (build 849)
Thanks.
Bob
2007-12-14 17:33:17
Hi Bob,
I think we've fixed this bug. I'll send you a private email with instructions how to test a beta version.
2008-02-09 10:46:30
update: these issues should be fixed in the 1.6.1 version.
