OiMutz
2007-12-09 20:01:52
It would be great to be able to insert variable delays between outgoing keystrokes. This would allow powerful automation, and would solve the issue I have when certain menu dropdown windows don't open quickly enough to receive the next keystroke in the sequence.
cheers,
2007-12-11 18:21:22
yes, a general delay for an outgoing action is a good idea.
Right now you can already do that with the Pro or Author version by using the timer feature:
instead of having this:
Translator: MIDI IN 90 40 pp -> Keystroke 'X'
use this:
Translator 1: MIDI IN 90 40 pp -> Timer "X-timer" with delay 500ms
Translator 2: Timer "X-Timer" -> Keystroke 'X'
Though, granted, it's more clumsy than a direct delay for the outgoing action.
