Can't switch presets
Bryan
2008-01-10 20:55:38
With MT Pro 1.60, unless I'm missing something, it seems that only the first preset in the list can be used. It used to be that one could activate a preset by clicking on it, no? Now it seems one must move it to the top.
2008-01-10 22:51:49
Hi Bryan,
right, previously, only the visible preset was active (plus the [always active preset).
Now, with version 1.6 and following, the little check mark to the left of the preset name indicates if the preset is active or not. So it's no problem to have many presets active at once.
Bryan
2008-01-11 00:30:25
Ah, OK.
It took me a while to see the Up and Down buttons for reordering rules. Perhaps they could look more button-like.
2008-01-11 14:02:13
good idea. will do.
