Can use MT to step sequence redrum with my EMX?
electroflux
2008-01-25 05:16:05
Hi i'm looking for some way to sequence drum patterns with redrum other than the mouse.I want to get away from using the mouse as much as possible as i can't use it for prolonged periodsan d i'd like to use a proper step seq if i can.After seeing the kid beyond video with Live i was hoping there might be.Is it possible?Thanks in advance,
Markus.
2008-01-28 20:00:56
Hi Markus,
I'm not sure if Reason's step sequencer allows programming the steps via MIDI. If yes, then it's probably very easy -- check out Reason's manual for that.
Otherwise, you can use MT Pro's Mouse move+click emulation to click on the steps in the step sequencer via MIDI or via keys on your computer keyboard.
electroflux
2008-01-30 16:45:09
florian wrote:Hi Markus,
Thanks florian!I thought MT pro might be able to do something like that :)
No reasons step seq. doesn't so i was looking for a workaround.
Cheers.
