Richard Soup
2008-03-04 23:03:10
I am using MT to change the routing on Abelton.
The problem is that when I set the mouse to move down - The results aren't always predictable.
The only way I can get round this is slowly manually move the mouse position every time before I use the re-routing routine - which seems to sort of flush out the system and then produces fairly predictable results.
Any thoughts gratefully accepted.
It would be great if I could get this to work as it has always been anoying that you can't automise the patching in Abelton.
cheers
Richard
cheers
Richard
