fpfs
2008-03-28 14:46:30
I've seen posts, so I know you're out there!
the situation
I own a Behringer BCF-2000 (i'm a musician, works fine without MT actually)
I play FSX
I think those throttle quadrants look ridiculous on a desk
I can't wait for the next MT pro to provide joystick support to start properly flying twin engine aircraft
so those eight faders are siting there, unused...
I had gotten the knobs to work already, even with MT classic with the knobs in rel1 mode. I still use that to trim my aircraft.
I got the faders to operate with MT classic to but it looked like making 45 separate translators per fader..... no way!
MT Pro brought the solution with rules.
It would have been even easier if i could send the F3 ket pp times but we have to start someplace.
hope you like it... leave a note if you do
I'll give the example of the no 1 engine throttle. the rest is copypaste...
- set the F3 key in FS controls to increase throttle quickly (iso incrementally)
- program the no 1 fader to ouput 45 steps (i found that to be the minimum proper control resolution)
Translator 1: THROTTLE 1 INIT
Options: stop=false
Incoming: MIDI B0 51 pp (maybe different control change message than 51 on your BCF preset)
ga=0
Outgoing: Keystroke: E 1 F1 (that's select engine one and close throttle completely)
Translator 2: THROTTLE 1 GO
Options: stop=false
ga=ga+2 (so, ok i could have halved the fader res still)
if ga>pp then exit rules, skip Outgoing Action
Outgoing: Keystroke: F3 F3 F3 F3 F3 F3
Repeat Translator 2 23 times
Translator 28: THROTTLE 1 FINISH
Options: stop=true
Outgoing: Keystroke: E (reset to al engines so yur key commands keep working)
the situation
I play FSX
Options: stop=false
ga=0
Options: stop=false
Options: stop=true
