mythhealer
2008-05-17 12:29:49
Background info:
I have been utilizing Live for the past few years, and over the past few days--managed to program the Classic MT. My FBC1010 has been programmed with the following capabilities: Undo, Delete, cursor left, cursor right... along with several functions that are assignable through Live. I will continue perfecting the programming of my FBC1010 with Classic MT before I begin any new session work. (to bypass all the BS about the evolution of this foot switch assignment system, and to go strait to the final program file itself, scroll down to my last post #6)
To be more specific about what I wish to achieve:
Fully MIDI controlled guitar solo recording process. I wish to capture a great idea, and have the computer edit this idea into a perfect two bar clip. This action is done over and over and over again durring the recording... so... a smooth flow between editing and recording with the computer acting as editor for me... that would be heaven!
How I use MT Classic:
The background music is started when I press the FCB1010's play button. It takes me anywhere from five two fifteen minutes to come up with a good melody, at this point I press the record button (launch). I now perform this melody until I'm happy with my performance (I am extremely picky here). The majority of the attempts at a good take are deleted. To delete it I press the stop button followed by the undo button. I, for the second attempt hit record (launch) once again. When I am satisfied with the recording, I move onto the next clip. It is this moving onto the next clip where I don't know how to automate the clean up of the recorded clip. When I coursor down to the next clip, the previous clip has a tail end greater than two bars in length. It is this little 'imperfection' I wish to have automated. The programming of a "clip save" button that includes a clip clean up prior to the moving onto the next clip -- followed by a play background music. In this way I have a clean recording session where I don't have a great deal of crap on my hard drive, and all clips are interchangable. Additionally, I never really know the order of melodies/clips until I have about three minutes of various melodies to choose from.
The FCB1010 button assignments I wish to have programmed, and their sub functions:
FCB1010 controller button assignments/functions:
Button 1
toggle - play/stop switch
Button 2
Record (activates launch in Live, pre set to record on launch)
Button 3
Undo - more specifically: stop music\undo currently recorded clip\record (launch) -- It removes my unwanted clip and re starts the recording process for additional takes. I will often press this button 5 to 10 times before I'm happy with the performance.
Button 4
Save - more specifically: stop music\change clip length to a perfect two bars\move down to next clip\start music playback. I go back to playback (not record) in order to come up with the next melodic idea.
If you go down to the 6th post in this string, I provide detailed information on how I got this 100% hands free, guitar solo recording process to work with MT Classic. It is version 3 (previous versions had problems that had to be corrected). The MT Classic file was opened in notepad file format, saved, and copied into post #6 of this string.
Button 1
Button 2
Button 3
Button 4
