Image_Engine
2008-06-05 01:33:12
Hi All
I have Live7 (lite) and FCB1010 and want to do the usual Kid Beyond type setup (I use Guitar with midi controller, plus a moveable mic on a percussion rack for the content) with a couple of other musicians. The 'Kid Beyond Style' rig by Chelfyn is a brilliant starting point but I need to add just one feature; I would like to be able to have a long press (or less preferably, a double click) on the footswitch, tell Live to delete the current track and rerecord on the next bar ie a single click (quick) will operate as currently implemented but a longer click and release will delete current slot and rerecord. Its a bit of a composite of some of the setups I have seen on the forum I know but the abovementioned would be perfect if it just had this ability as sometimes the first recorded progression isnt the best, as the ideas formulate a bit as you repeat etc. Im not really using the resample but I may as I mature using it.
Any help greatly appreciated. I have not as yet programmed the FCB so a note of within a certain time or whatever would be fine but Im a bit unsure of how to achieve this; with a timer?
Regs
Mark
Regs
Mark
