Image_Engine
2008-06-07 09:54:18
Hi
I simply want to remap a note or controller on ch13 to 14. I looked through the presets and saw an example on the forum to replace the channel but not a simple fixed output?
REgs
M
2008-06-07 17:41:41
what do you mean with "simple fixed output"? If you want to convert controller 00 from channel 13 to 14, then do this:
INCOMING: MIDI BC 00 pp
OUTGOING: MIDI BD 00 pp
That maps channel 13 (which is 12 in MIDI messages, because channel counting starts at 0 in MIDI messages, and 12 hexadecimal = C) to channel 14 statically (no rules needed).
Image_Engine
2008-06-07 22:41:46
Hi Florian]
Vielen Dank! Yes...I worked it out before bed but as mentioned in another post, LIve is fixed on seeing all prog change as pitch bend for some reason. I thought I was somehow corrupting the throughput. Oh well. I should have been finished but...you know how code can be sometimes...no matter what the format!
Thanks for the excellent help on this forum, guys
Regs
Mark
