apell08
2008-08-05 12:30:16
I am using the foot pedals of basic midi drum controller that sends out each drum pad and foot pedal as a midi note.
Using MT Classic I have been able to use one of the foot pedals to trigger the Key Press of the QWERTY keyboard “down” button to change scenes in Ableton Live. My problem is that it repeats the “down” action twice even after I placed a Key Up event following the Key Press or Key Down (with No Repat) in the same Preset.
All I want is to press the foot pedal and go “down” once! I have also tried this through a normal midi controller piano keyboard with the same problem occuring.
The details in MT are:
1st TRANSLATOR
Incoming MIDI
Note On #10: G#2, vel pp
99 2C pp
Outgoing Keystroke Emulation
Key Press event OR Key Down (No Repeat)
2nd TRANSLATOR
Incoming MIDI
99 2C pp
Key Up event
Any advice or solution to help fix this problem or to let me know what I am doing wrong would be greatly appreciated.
1st TRANSLATOR
Incoming MIDI
99 2C pp
2nd TRANSLATOR
Incoming MIDI
99 2C pp
Key Up event
