litL1
2008-09-04 21:58:13
I am trying to input the number 1 value from a notebook keyboard, using the "fn"-key, into the Outgoing trigger, as a Key Press, but apart from getting random values in the form of [VK 1847xxxxx] where "x" is a number, which seems to change on every successive press of fn+1, nothing happens in A.Live7. What should happen is for A.Live to arm Track1.
I can arm it, using fn+1 directly on the keyboard.
When i use the fn-key in combination with another key, say the arrow keys, or the F-keys, the Outgoing trigger Display shows either "Num 3" etc. or "F6", as expected.
Unfortunately there seems to be no way to copy/paste into the trigger display, or to type the command in, as any such action is imediately converted to a keystroke sequence...
Any help in achieving the above would be greatly appreciated!
In the meantime, i will have to change my key-map in A.Live.
***ONE LOVE***
litL1
***ONE LOVE***
litL1
