litL1
2008-09-06 13:35:42
MacOSX: BMT Pro Beta Test-2 (05-09-2008)
Program/UI Issues
(***) I had noticed that, after saving a project, the new file name did not appear in the name field at the top af the app, and trying to re-save it (assuming that the behaviour should be for the saved file to be the currently active one), BMT crashed.
Program/UI Issues
- 1. In the Outgoing Trigger message field, when "None" type is chosen, it says: This special Outgoing Action do not do anything in response of Outgoing Action. It can be..., and i'm wondering if this shouldn't read: This special Outgoing Action does not do anything in response of Incoming Actions. It can be...?
2. When the value in Incoming: trigger type "MIDI message" is a Note On 30 "C3", 40 "C4", or 50 "C5", e.g. 90 30 oo, the Editor's HEX<->DECIMAL Translator and the Main Window's "Incoming Trigger" column description do not show its Note On name as "C" , as it does show "C#3" for 90 31 oo, "D" for 90 32 oo, etc, but show only the octave number.
3. When testing a function, with BMT being the frontmost window, it happens that the Preset or Translator Name field becomes active and the value of the applied key is inadvertently being entered.
4. Please see (***) below.
Date/Time: 2008-09-05 22:27:58.577 +0200
OS Version: 10.4.11 (Build 8S165)
Report Version: 4
Command: JavaApplicationStub
Path: /Applications/Bome's Midi Translator.app/Contents/MacOS/JavaApplicationStub
Parent: WindowServer [56]
Version: 1.0 (1.6.1)
PID: 268
Thread: 12
Exception: EXC_BAD_ACCESS (0x0001)
Code[0]: 0x00000103
Code[1]: 0x286f6f3a
Thread 0:
0 libSystem.B.dylib 0x9000b348 mach_msg_trap + 8
1 libSystem.B.dylib 0x9000b29c mach_msg + 60
2 com.apple.CoreFoundation 0x907de9ac __CFRunLoopRun + 832
3 com.apple.CoreFoundation 0x907de2b0 CFRunLoopRunSpecific + 268
4 com.apple.HIToolbox 0x932acb20 RunCurrentEventLoopInMode + 264
5 com.apple.HIToolbox 0x932ac1b4 ReceiveNextEventCommon + 380
6 com.apple.HIToolbox 0x932ac020 BlockUntilNextEventMatchingListInMode + 96
7 com.apple.AppKit 0x93791734 _DPSNextEvent + 384
8 com.apple.AppKit 0x937913f8 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 116
9 com.apple.AppKit 0x9378d93c -[NSApplication run] + 472
10 libawt.jnilib 0x9fe4c808 +[AWTStarter startAWT:] + 1848
11 com.apple.Foundation 0x92c01980 __NSFireMainThreadPerform + 276
12 com.apple.CoreFoundation 0x9080f928 __CFRunLoopPerformPerform + 104
13 com.apple.CoreFoundation 0x907df300 __CFRunLoopDoSources0 + 384
14 com.apple.CoreFoundation 0x907de830 __CFRunLoopRun + 452
15 com.apple.CoreFoundation 0x907de2b0 CFRunLoopRunSpecific + 268
16 ...ple.JavaApplicationLauncher 0x95351954 startupJava(int, int, char const* const*, __CFDictionary const*, BuilderVersion, char const*, char const**) + 296
17 JavaApplicationStub 0x0000808c 0x1000 + 28812
18 JavaApplicationStub 0x00007d90 0x1000 + 28048
Thread 12 Crashed:
0 libstdc++.6.dylib 0x94c8c0c8 _gnu_cxx::__atomic_add(int volatile*, int) + 0
1 <<00000000>> 0x0482dd0c 0 + 75685132
2 libstdc++.6.dylib 0x94c78f58 std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string[in-charge](std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 76
3 libmt.so 0x0a1f3090 Java_com_bome_mt_jni_TTransChangePresetAction__1_1getPresetName + 40
4 <<00000000>> 0x04591264 0 + 72946276
5 <<00000000>> 0x0458a9c0 0 + 72919488
6 <<00000000>> 0x0458a9c0 0 + 72919488
7 <<00000000>> 0x0458aab0 0 + 72919728
8 <<00000000>> 0x0458aab0 0 + 72919728
9 <<00000000>> 0x0458ae10 0 + 72920592
10 <<00000000>> 0x0458aab0 0 + 72919728
11 <<00000000>> 0x0458aab0 0 + 72919728
12 <<00000000>> 0x0458aab0 0 + 72919728
13 <<00000000>> 0x0458a930 0 + 72919344
14 <<00000000>> 0x0458aab0 0 + 72919728
15 <<00000000>> 0x0458ae10 0 + 72920592
16 <<00000000>> 0x0458aab0 0 + 72919728
17 <<00000000>> 0x0458ae10 0 + 72920592
18 <<00000000>> 0x0458aab0 0 + 72919728
19 <<00000000>> 0x0458ae10 0 + 72920592
20 <<00000000>> 0x0458aab0 0 + 72919728
21 <<00000000>> 0x0458ae10 0 + 72920592
22 <<00000000>> 0x0458aab0 0 + 72919728
23 <<00000000>> 0x0458aab0 0 + 72919728
24 <<00000000>> 0x04746460 0 + 74736736
25 <<00000000>> 0x04723a24 0 + 74594852
26 <<00000000>> 0x0484aea4 0 + 75804324
27 <<00000000>> 0x0469f400 0 + 74052608
28 <<00000000>> 0x0458aab0 0 + 72919728
29 <<00000000>> 0x0458aab0 0 + 72919728
30 <<00000000>> 0x0458aab0 0 + 72919728
31 <<00000000>> 0x04588164 0 + 72909156
32 libjvm.dylib 0x9c26bd38 jio_snprintf + 397640
33 libjvm.dylib 0x9c279444 JVM_StartThread + 2612
34 libjvm.dylib 0x9c279330 JVM_StartThread + 2336
35 libjvm.dylib 0x9c2792c0 JVM_StartThread + 2224
36 libjvm.dylib 0x9c27917c JVM_StartThread + 1900
37 libjvm.dylib 0x9c20418c JNI_CreateJavaVM_Impl + 48364
38 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 12 crashed with PPC Thread State 64:
srr0: 0x0000000094c8c0c8 srr1: 0x000000000200f030 vrsave: 0x0000000000000000
cr: 0x48000218 xer: 0x0000000020000002 lr: 0x0000000094c77980 ctr: 0x0000000094c78f0c
r0: 0x0000000094c78f58 r1: 0x00000000f0f0db00 r2: 0x00000000a4c50d8c r3: 0x00000000286f6f3a
r4: 0x0000000000000001 r5: 0x00000000f0f0db89 r6: 0x00000000003ccb40 r7: 0x000000007000000a
r8: 0x0000000070800003 r9: 0x00000000fffffff0 r10: 0x0000000026fc9430 r11: 0x000000000a25904c
r12: 0x0000000094c78f0c r13: 0x00000000005125f0 r14: 0x000000000460cdfc r15: 0x000000000a1f3068
r16: 0x00000000f0f0dc80 r17: 0x000000002a8956a0 r18: 0x00000000f0f0dcd4 r19: 0x00000000f0f0dc68
r20: 0x000000002a895a80 r21: 0x000000002a8956a0 r22: 0x00000000000000b7 r23: 0x00000000f0f0e848
r24: 0x000000002e6902cc r25: 0x000000002ef0fd58 r26: 0x00000000f0f0dbfc r27: 0x00000000f0f0db8a
r28: 0x00000000f0f0db89 r29: 0x00000000286f6f32 r30: 0x00000000286f6f32 r31: 0x0000000094c77950
Binary Images Description:
0x1000 - 0x9fff JavaApplicationStub 1.0 (1.6.1) /Applications/Bome's Midi Translator.app/Contents/MacOS/JavaApplicationStub
0xa191000 - 0xa256fff libmt.so /Applications/Bome's Midi Translator.app/Contents/Resources/Java/libmt.so
0x8fe00000 - 0x8fe52fff dyld 46.16 /usr/lib/dyld
0x90000000 - 0x901bcfff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x90214000 - 0x90219fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x9021b000 - 0x90268fff com.apple.CoreText 1.0.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90293000 - 0x90344fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90373000 - 0x9072efff com.apple.CoreGraphics 1.258.79 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x907bb000 - 0x90895fff com.apple.CoreFoundation 6.4.11 (368.35) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x908de000 - 0x908defff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x908e0000 - 0x909e2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a3c000 - 0x90ac0fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90aea000 - 0x90b5cfff com.apple.framework.IOKit 1.4 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90b72000 - 0x90b84fff libauto.dylib /usr/lib/libauto.dylib
0x90b8b000 - 0x90e62fff com.apple.CoreServices.CarbonCore 681.18 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90ec8000 - 0x90f48fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90f92000 - 0x90fd4fff com.apple.CFNetwork 4.0 (129.23) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90fe9000 - 0x91001fff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91011000 - 0x91092fff com.apple.SearchKit 1.0.7 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x910d8000 - 0x91101fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91112000 - 0x91120fff libz.1.dylib /usr/lib/libz.1.dylib
0x91123000 - 0x912defff com.apple.security 4.6 (29770) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913dd000 - 0x913e6fff com.apple.DiskArbitration 2.1.2 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x913ed000 - 0x913f5fff libbsm.dylib /usr/lib/libbsm.dylib
0x913f9000 - 0x91421fff com.apple.SystemConfiguration 1.8.3 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91434000 - 0x9143ffff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x91444000 - 0x914bffff com.apple.audio.CoreAudio 3.0.5 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x914fc000 - 0x914fcfff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x914fe000 - 0x91536fff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91551000 - 0x91623fff com.apple.ColorSync 4.4.10 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91676000 - 0x91707fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9174e000 - 0x91805fff com.apple.QD 3.10.25 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91842000 - 0x918a0fff com.apple.HIServices 1.5.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x918cf000 - 0x918f0fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91904000 - 0x91929fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x9193c000 - 0x9197efff com.apple.LaunchServices 183 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9199a000 - 0x919aefff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x919bc000 - 0x91a02fff com.apple.ImageIO.framework 1.5.7 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91a19000 - 0x91ae0fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91b2e000 - 0x91b43fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91b48000 - 0x91b66fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91b6c000 - 0x91c23fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91c72000 - 0x91c76fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91c78000 - 0x91ce2fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91ce7000 - 0x91d24fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91d2b000 - 0x91d45fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91d4a000 - 0x91d4dfff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91d4f000 - 0x91e3dfff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x91e5c000 - 0x91e5cfff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91e5e000 - 0x91f43fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91f4b000 - 0x91f6afff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91fd6000 - 0x92044fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9204f000 - 0x920e4fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x920fe000 - 0x92686fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x926b9000 - 0x929e4fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92a14000 - 0x92b02fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92b05000 - 0x92b8dfff com.apple.DesktopServices 1.3.7 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x92bce000 - 0x92df9fff com.apple.Foundation 6.4.10 (567.37) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92f26000 - 0x92f44fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92f4f000 - 0x92fa9fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92fc7000 - 0x92fc7fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92fc9000 - 0x92fddfff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92ff5000 - 0x93005fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x93011000 - 0x93026fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93038000 - 0x930bffff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x930d3000 - 0x930defff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x930e8000 - 0x93116fff com.apple.openscripting 1.2.7 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x93130000 - 0x9313ffff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9314b000 - 0x931b1fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x931e2000 - 0x93231fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9325f000 - 0x9327cfff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9328e000 - 0x9329bfff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x932a4000 - 0x935b2fff com.apple.HIToolbox 1.4.10 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93702000 - 0x9370efff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x93740000 - 0x93745fff com.apple.JavaVM 11.7.0 /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
0x93787000 - 0x93787fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93789000 - 0x93dbcfff com.apple.AppKit 6.4.10 (824.48) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x94149000 - 0x941bbfff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x941f4000 - 0x942b9fff com.apple.audio.toolbox.AudioToolbox 1.4.7 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9430c000 - 0x9430cfff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9430e000 - 0x944cefff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x94518000 - 0x94555fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
0x9455d000 - 0x945adfff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x945b6000 - 0x945d1fff com.apple.CoreVideo 1.4.2 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x945e2000 - 0x94602fff libmx.A.dylib /usr/lib/libmx.A.dylib
0x947a5000 - 0x947b4fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x947bc000 - 0x947c9fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x9480f000 - 0x94828fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x9482f000 - 0x94b5bfff com.apple.QuickTime 7.5.0 (861) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94c42000 - 0x94cb3fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x9534d000 - 0x9535efff com.apple.JavaApplicationLauncher 11.7.0 /System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher
0x973c5000 - 0x97404fff com.apple.audio.midi.CoreMIDI 1.5 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x98be8000 - 0x98be9fff liblauncher.jnilib /System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/Resources/liblauncher.jnilib
0x9c1f7000 - 0x9c571fff libjvm.dylib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libjvm.dylib
0x9c59f000 - 0x9c59ffff libcmm.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libcmm.jnilib
0x9c5dc000 - 0x9c5fafff libjava.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libjava.jnilib
0x9c605000 - 0x9c60dfff libverify.dylib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libverify.dylib
0x9c66e000 - 0x9c694fff libjpeg.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libjpeg.jnilib
0x9c6d6000 - 0x9c6e2fff libnet.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libnet.jnilib
0x9c6e6000 - 0x9c6ebfff libnio.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libnio.jnilib
0x9c6f1000 - 0x9c739fff libsuncmm.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libsuncmm.jnilib
0x9c742000 - 0x9c74ffff libzip.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libzip.jnilib
0x9fdbf000 - 0x9fe21fff libfontmanager.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libfontmanager.jnilib
0x9fe37000 - 0x9fe45fff liblaf.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/liblaf.jnilib
0x9fe4a000 - 0x9ffa6fff libawt.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libawt.jnilib
