litL1
2008-09-07 05:53:54
Program/UI Issues
Oh, and i'm sorry, if these crash reports are getting on your nerves, but i won't be sending any more for now, and wait till i get some feed-back about their usefulness.
Program Crash Reports
BMT crashed on a relatively small project file, this time. So, my previous suspicion (see "Various Bugs Report" 05-09-2008) about the complexity of the project affecting the crash, is probably not correct.
The project crashing, consisted of 3 Presets, of which one was the (always active) Preset with one translator deactivating all Presets bar one + the (always active) on opening the project; the other two Presets had each one translator; the first a "Note On" as Incoming Trigger, and as an Outgoing Trigger activating the second. The second Preset didn't yet have its one translator's incoming and outgoing triggers defined. The crash occurred upon double-clicking that translator in order to define the triggers.
I actually had about 4 or 5 crashes in between these two reported ones, but i was so in the flow of editing, that i didn't want to stop to collect this data (seeing that there hasn't been a reply so far, i guess it's not that vital anyhow, is it?), sorry. But since the main commitment i undertook in getting this software was to beta test it, i'll keep on doing this, though it is a bit frustrating that it should crash so often and confusing to not see anyone else reporting this... as far as i can say, i have not had so many crashes with any software i use, since the days of Win98 ... and i sure don't care to remember them too often.
So, what's up with that? Is anybody else testing this on a Mac with similar spec? having any such issues? Am i the only one left using a G4 iBook... probably
Anyhow, i just deleted a translator; the project is relatively light - only ca. 3 Translators in 3 Presets.. Non of the translating is heavy duty maths and rules. If anything, i am spending chunks of 10 - 20 minutes in between changing anything in BMT, while reading in the forum to learn about the software... I had some dinner, leaving the PC for about a couple of hours. Following this long a break, i actually have now come to expect a crash, and necessary reboot of BMT. Non of my other apps, which are open at the same time (TextEdit, A.Live, internet browser) are affected by this.
- 1. As i tabbed my way through the Editor, following entering a value in the "Timer" Assignment field, the help test right below suddenly become active, i.e. i inadvertently deleted that text, by trying out my assignment on the MIDI-keyboard!! I then saved and reopened the project and, placing the curser again somewhere inside the text, i could actually repeat this; delete words, type in new text, etz.
2. "Error: executing Preset | Top: translator not found: index out of bounds". I reported this before, but i this time managed to copy the exact Error message. While most of the time it works, moving a Preset from below the (always active) Preset to the top, it keeps happening sporadically, and the only way i found so far is to first move it above the (a a) Preset and then to the top.
Actually most of the hick-ups, mentioned in previous reports, happened again and more than once!
3. I had the tempo field of A.Live in focus, as i hit a Note on my MIDI keyboard, which was translating. The value was entered into the tempo field.
4. BMT has unfortunately crashed so often, that it managed quite well to rob me of the fun and excitement i was so up for tonight
Date/Time: 2008-09-06 17:04:04.233 +0200
OS Version: 10.4.11 (Build 8S165)
Report Version: 4
Command: JavaApplicationStub
Path: /Applications/Bome's Midi Translator.app/Contents/MacOS/JavaApplicationStub
Parent: WindowServer [56]
Version: 1.0 (1.6.1)
PID: 259
Thread: 12
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_INVALID_ADDRESS (0x0001) at 0xe14acf20
Thread 0:
0 libSystem.B.dylib 0x9000b348 mach_msg_trap + 8
1 libSystem.B.dylib 0x9000b29c mach_msg + 60
2 com.apple.CoreFoundation 0x907de9ac __CFRunLoopRun + 832
3 com.apple.CoreFoundation 0x907de2b0 CFRunLoopRunSpecific + 268
4 com.apple.HIToolbox 0x932acb20 RunCurrentEventLoopInMode + 264
5 com.apple.HIToolbox 0x932ac1b4 ReceiveNextEventCommon + 380
6 com.apple.HIToolbox 0x932ac020 BlockUntilNextEventMatchingListInMode + 96
7 com.apple.AppKit 0x93791734 _DPSNextEvent + 384
8 com.apple.AppKit 0x937913f8 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 116
9 com.apple.AppKit 0x9378d93c -[NSApplication run] + 472
10 libawt.jnilib 0x9fe4c808 +[AWTStarter startAWT:] + 1848
11 com.apple.Foundation 0x92c01980 __NSFireMainThreadPerform + 276
12 com.apple.CoreFoundation 0x9080f928 __CFRunLoopPerformPerform + 104
13 com.apple.CoreFoundation 0x907df300 __CFRunLoopDoSources0 + 384
14 com.apple.CoreFoundation 0x907de830 __CFRunLoopRun + 452
15 com.apple.CoreFoundation 0x907de2b0 CFRunLoopRunSpecific + 268
16 ...ple.JavaApplicationLauncher 0x95351954 startupJava(int, int, char const* const*, __CFDictionary const*, BuilderVersion, char const*, char const**) + 296
17 JavaApplicationStub 0x0000808c 0x1000 + 28812
18 JavaApplicationStub 0x00007d90 0x1000 + 28048
Thread 1:
2 libjvm.dylib 0x9c26a460 jio_snprintf + 391280
3 libjvm.dylib 0x9c26a284 jio_snprintf + 390804
4 libjvm.dylib 0x9c2e6540 JVM_Write + 21584
5 libjvm.dylib 0x9c2e6078 JVM_Write + 20360
6 ...ple.JavaApplicationLauncher 0x95350180 startJavaApplication + 4000
7 ...ple.JavaApplicationLauncher 0x9534f1d8 java_main_stub(void*) + 72
8 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 2:
2 libjvm.dylib 0x9c2042fc JNI_CreateJavaVM_Impl + 48732
3 libjvm.dylib 0x9c204294 JNI_CreateJavaVM_Impl + 48628
4 libjvm.dylib 0x9c20418c JNI_CreateJavaVM_Impl + 48364
5 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 3:
2 libjvm.dylib 0x9c26a5a0 jio_snprintf + 391600
3 libjvm.dylib 0x9c26a1a4 jio_snprintf + 390580
4 libjvm.dylib 0x9c26a96c jio_snprintf + 392572
5 libjvm.dylib 0x9c269fe8 jio_snprintf + 390136
6 libjvm.dylib 0x9c20418c JNI_CreateJavaVM_Impl + 48364
7 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 4:
3 libjvm.dylib 0x9c27a1e4 JVM_MonitorWait + 3028
4 libjvm.dylib 0x9c2798ac JVM_MonitorWait + 668
5 <<00000000>> 0x04591264 0 + 72946276
6 <<00000000>> 0x0458aab0 0 + 72919728
7 <<00000000>> 0x0458aab0 0 + 72919728
8 <<00000000>> 0x04588164 0 + 72909156
9 libjvm.dylib 0x9c26bd38 jio_snprintf + 397640
10 libjvm.dylib 0x9c279444 JVM_StartThread + 2612
11 libjvm.dylib 0x9c279330 JVM_StartThread + 2336
12 libjvm.dylib 0x9c2792c0 JVM_StartThread + 2224
13 libjvm.dylib 0x9c27917c JVM_StartThread + 1900
14 libjvm.dylib 0x9c20418c JNI_CreateJavaVM_Impl + 48364
15 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 5:
7 <<00000000>> 0x0458a9c0 0 + 72919488
8 <<00000000>> 0x0458a9c0 0 + 72919488
9 <<00000000>> 0x04588164 0 + 72909156
10 libjvm.dylib 0x9c26bd38 jio_snprintf + 397640
11 libjvm.dylib 0x9c279444 JVM_StartThread + 2612
12 libjvm.dylib 0x9c279330 JVM_StartThread + 2336
13 libjvm.dylib 0x9c2792c0 JVM_StartThread + 2224
14 libjvm.dylib 0x9c27917c JVM_StartThread + 1900
15 libjvm.dylib 0x9c20418c JNI_CreateJavaVM_Impl + 48364
16 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 6:
0 libSystem.B.dylib 0x9002c4b8 semaphore_wait_trap + 8
1 libjvm.dylib 0x9c28ed88 JVM_RegisterSignal + 10104
2 libjvm.dylib 0x9c28eab4 JVM_RegisterSignal + 9380
Thread 7:
4 libjvm.dylib 0x9c28ff80 JVM_RegisterSignal + 14704
5 libjvm.dylib 0x9c28fc38 JVM_RegisterSignal + 13864
6 libjvm.dylib 0x9c27917c JVM_StartThread + 1900
7 libjvm.dylib 0x9c20418c JNI_CreateJavaVM_Impl + 48364
Thread 8:
4 libjvm.dylib 0x9c290604 JVM_RegisterSignal + 16372
5 libjvm.dylib 0x9c27917c JVM_StartThread + 1900
Thread 9:
3 libjvm.dylib 0x9c2a5a84 JVM_RegisterSignal + 103540
4 libjvm.dylib 0x9c2a56a8 JVM_RegisterSignal + 102552
Thread 10:
8 <<00000000>> 0x0458ae10 0 + 72920592
Thread 11:
9 <<00000000>> 0x0458ae10 0 + 72920592
10 <<00000000>> 0x04588164 0 + 72909156
11 libjvm.dylib 0x9c26bd38 jio_snprintf + 397640
12 libjvm.dylib 0x9c279444 JVM_StartThread + 2612
13 libjvm.dylib 0x9c279330 JVM_StartThread + 2336
14 libjvm.dylib 0x9c2792c0 JVM_StartThread + 2224
15 libjvm.dylib 0x9c27917c JVM_StartThread + 1900
16 libjvm.dylib 0x9c20418c JNI_CreateJavaVM_Impl + 48364
17 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 12 Crashed:
0 libmt.so 0x0a478208 Tr::formatString(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 72
1 libmt.so 0x0a4782b0 Tr::TTransMidiAction::GetMidiString() + 28
2 libmt.so 0x0a4d2ea0 Java_com_bome_mt_jni_TTransMidiAction__1_1getMidiString + 40
3 <<00000000>> 0x04591264 0 + 72946276
4 <<00000000>> 0x0458a9c0 0 + 72919488
5 <<00000000>> 0x0458a9c0 0 + 72919488
9 <<00000000>> 0x0458aab0 0 + 72919728
10 <<00000000>> 0x0458aab0 0 + 72919728
11 <<00000000>> 0x0458aab0 0 + 72919728
12 <<00000000>> 0x0458ae10 0 + 72920592
13 <<00000000>> 0x0469c2b0 0 + 74039984
14 <<00000000>> 0x0458aab0 0 + 72919728
15 <<00000000>> 0x0458aab0 0 + 72919728
16 <<00000000>> 0x0458aab0 0 + 72919728
17 <<00000000>> 0x0458ae10 0 + 72920592
18 <<00000000>> 0x0458aab0 0 + 72919728
19 <<00000000>> 0x0458aab0 0 + 72919728
20 <<00000000>> 0x0458ae10 0 + 72920592
21 <<00000000>> 0x0458aab0 0 + 72919728
22 <<00000000>> 0x0458ae10 0 + 72920592
23 <<00000000>> 0x0458aab0 0 + 72919728
24 <<00000000>> 0x0458ae10 0 + 72920592
25 <<00000000>> 0x0458ae10 0 + 72920592
26 <<00000000>> 0x0458ae10 0 + 72920592
27 <<00000000>> 0x0458aab0 0 + 72919728
28 <<00000000>> 0x0476fc4c 0 + 74906700
29 <<00000000>> 0x0476ba74 0 + 74889844
30 <<00000000>> 0x04729580 0 + 74618240
31 <<00000000>> 0x0471cc98 0 + 74566808
32 <<00000000>> 0x04704c9c 0 + 74468508
33 <<00000000>> 0x04765c34 0 + 74865716
34 <<00000000>> 0x04754234 0 + 74793524
35 <<00000000>> 0x0471cc38 0 + 74566712
36 <<00000000>> 0x047520f0 0 + 74785008
37 <<00000000>> 0x0472f4d8 0 + 74642648
38 <<00000000>> 0x046dcd24 0 + 74304804
39 <<00000000>> 0x0458a930 0 + 72919344
40 <<00000000>> 0x0458aab0 0 + 72919728
41 <<00000000>> 0x0458aab0 0 + 72919728
42 <<00000000>> 0x0458aab0 0 + 72919728
43 <<00000000>> 0x04588164 0 + 72909156
44 libjvm.dylib 0x9c26bd38 jio_snprintf + 397640
45 libjvm.dylib 0x9c279444 JVM_StartThread + 2612
46 libjvm.dylib 0x9c279330 JVM_StartThread + 2336
47 libjvm.dylib 0x9c2792c0 JVM_StartThread + 2224
48 libjvm.dylib 0x9c27917c JVM_StartThread + 1900
49 libjvm.dylib 0x9c20418c JNI_CreateJavaVM_Impl + 48364
50 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 13:
Thread 14:
2 com.apple.audio.midi.CoreMIDI 0x973d2ac8 XServerMachPort::ReceiveMessage(int&, void*, int&) + 84
3 com.apple.audio.midi.CoreMIDI 0x973c5c80 MIDIInPortThread::Run() + 64
4 com.apple.audio.midi.CoreMIDI 0x973c9f44 XThread::RunHelper(void*) + 28
5 com.apple.audio.midi.CoreMIDI 0x973d387c CAPThread::Entry(CAPThread*) + 96
Thread 15:
0 libSystem.B.dylib 0x90130d78 semaphore_timedwait_trap + 8
1 libSystem.B.dylib 0x90070c28 pthread_cond_timedwait_relative_np + 620
2 libmt.so 0x0a484568 bthread_cond_wait(bthread_cond_t*, int, int) + 408
3 libmt.so 0x0a4a3cec Tr::TRuntimeDispatcher::Execute() + 84
4 libmt.so 0x0a49cd88 Tr::TThread::run(void*) + 48
Thread 16:
3 libjvm.dylib 0x9c2a5930 JVM_RegisterSignal + 103200
4 libjvm.dylib 0x9c336654 JVM_Sleep + 468
5 <<00000000>> 0x046fbf1c 0 + 74432284
6 <<00000000>> 0x047002a8 0 + 74449576
7 <<00000000>> 0x04701740 0 + 74454848
Thread 17:
Thread 12 crashed with PPC Thread State 64:
srr0: 0x000000000a478208 srr1: 0x000000000200f030 vrsave: 0x0000000000000000
cr: 0x48000204 xer: 0x0000000000000004 lr: 0x000000000a4782b0 ctr: 0x000000000a4d2e78
r0: 0x00000000f0e8c310 r1: 0x00000000f0e8c2b0 r2: 0x00000000f0620c70 r3: 0x00000000f0e8c39c
r4: 0x000000000198a81c r5: 0x0000000000000000 r6: 0x000000000198a800 r7: 0x000000000198a81c
r8: 0x000000000a694cfb r9: 0x000000000a66febc r10: 0x0000000026f396b0 r11: 0x0000000000000000
r12: 0x0000000000000000 r13: 0x0000000000512070 r14: 0x000000000460cdfc r15: 0x000000000a4d2e78
r16: 0x00000000f0e8c420 r17: 0x000000002a7fee18 r18: 0x00000000f0e8c474 r19: 0x00000000f0e8c408
r20: 0x000000002a807ac8 r21: 0x000000002a7fee18 r22: 0x00000000000000b7 r23: 0x0000000000000012
r24: 0x000000000000001a r25: 0x00000000265adea0 r26: 0x0000000026edd568 r27: 0x0000000026cccda0
r28: 0x0000000026ccd3f0 r29: 0x00000000f0e8c39c r30: 0x00000000f0e8c2b0 r31: 0x000000000a4d2e84
Binary Images Description:
0x1000 - 0x9fff JavaApplicationStub 1.0 (1.6.1) /Applications/Bome's Midi Translator.app/Contents/MacOS/JavaApplicationStub
0xa470000 - 0xa535fff libmt.so /Applications/Bome's Midi Translator.app/Contents/Resources/Java/libmt.so
0x8fe00000 - 0x8fe52fff dyld 46.16 /usr/lib/dyld
0x90000000 - 0x901bcfff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x90214000 - 0x90219fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x9021b000 - 0x90268fff com.apple.CoreText 1.0.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90293000 - 0x90344fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90373000 - 0x9072efff com.apple.CoreGraphics 1.258.79 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x907bb000 - 0x90895fff com.apple.CoreFoundation 6.4.11 (368.35) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x908de000 - 0x908defff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x908e0000 - 0x909e2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a3c000 - 0x90ac0fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90aea000 - 0x90b5cfff com.apple.framework.IOKit 1.4 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90b72000 - 0x90b84fff libauto.dylib /usr/lib/libauto.dylib
0x90b8b000 - 0x90e62fff com.apple.CoreServices.CarbonCore 681.18 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90ec8000 - 0x90f48fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90f92000 - 0x90fd4fff com.apple.CFNetwork 4.0 (129.23) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90fe9000 - 0x91001fff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91011000 - 0x91092fff com.apple.SearchKit 1.0.7 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x910d8000 - 0x91101fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91112000 - 0x91120fff libz.1.dylib /usr/lib/libz.1.dylib
0x91123000 - 0x912defff com.apple.security 4.6 (29770) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x913dd000 - 0x913e6fff com.apple.DiskArbitration 2.1.2 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x913ed000 - 0x913f5fff libbsm.dylib /usr/lib/libbsm.dylib
0x913f9000 - 0x91421fff com.apple.SystemConfiguration 1.8.3 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91434000 - 0x9143ffff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x91444000 - 0x914bffff com.apple.audio.CoreAudio 3.0.5 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x914fc000 - 0x914fcfff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x914fe000 - 0x91536fff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91551000 - 0x91623fff com.apple.ColorSync 4.4.10 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91676000 - 0x91707fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9174e000 - 0x91805fff com.apple.QD 3.10.25 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91842000 - 0x918a0fff com.apple.HIServices 1.5.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x918cf000 - 0x918f0fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91904000 - 0x91929fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x9193c000 - 0x9197efff com.apple.LaunchServices 183 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9199a000 - 0x919aefff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x919bc000 - 0x91a02fff com.apple.ImageIO.framework 1.5.7 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91a19000 - 0x91ae0fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91b2e000 - 0x91b43fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91b48000 - 0x91b66fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91b6c000 - 0x91c23fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91c72000 - 0x91c76fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91c78000 - 0x91ce2fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91ce7000 - 0x91d24fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91d2b000 - 0x91d45fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91d4a000 - 0x91d4dfff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91d4f000 - 0x91e3dfff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x91e5c000 - 0x91e5cfff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91e5e000 - 0x91f43fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91f4b000 - 0x91f6afff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91fd6000 - 0x92044fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9204f000 - 0x920e4fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x920fe000 - 0x92686fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x926b9000 - 0x929e4fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92a14000 - 0x92b02fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x92b05000 - 0x92b8dfff com.apple.DesktopServices 1.3.7 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x92bce000 - 0x92df9fff com.apple.Foundation 6.4.10 (567.37) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92f26000 - 0x92f44fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92f4f000 - 0x92fa9fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92fc7000 - 0x92fc7fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92fc9000 - 0x92fddfff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92ff5000 - 0x93005fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x93011000 - 0x93026fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93038000 - 0x930bffff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x930d3000 - 0x930defff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x930e8000 - 0x93116fff com.apple.openscripting 1.2.7 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x93130000 - 0x9313ffff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9314b000 - 0x931b1fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x931e2000 - 0x93231fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9325f000 - 0x9327cfff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9328e000 - 0x9329bfff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x932a4000 - 0x935b2fff com.apple.HIToolbox 1.4.10 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93702000 - 0x9370efff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x93740000 - 0x93745fff com.apple.JavaVM 11.7.0 /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
0x93787000 - 0x93787fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93789000 - 0x93dbcfff com.apple.AppKit 6.4.10 (824.48) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x94149000 - 0x941bbfff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x941f4000 - 0x942b9fff com.apple.audio.toolbox.AudioToolbox 1.4.7 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9430c000 - 0x9430cfff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9430e000 - 0x944cefff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x94518000 - 0x94555fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
0x9455d000 - 0x945adfff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x945b6000 - 0x945d1fff com.apple.CoreVideo 1.4.2 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x945e2000 - 0x94602fff libmx.A.dylib /usr/lib/libmx.A.dylib
0x947a5000 - 0x947b4fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x947bc000 - 0x947c9fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x9480f000 - 0x94828fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x9482f000 - 0x94b5bfff com.apple.QuickTime 7.5.0 (861) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94c42000 - 0x94cb3fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x9534d000 - 0x9535efff com.apple.JavaApplicationLauncher 11.7.0 /System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher
0x973c5000 - 0x97404fff com.apple.audio.midi.CoreMIDI 1.5 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x98be8000 - 0x98be9fff liblauncher.jnilib /System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/Resources/liblauncher.jnilib
0x9c1f7000 - 0x9c571fff libjvm.dylib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libjvm.dylib
0x9c59f000 - 0x9c59ffff libcmm.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libcmm.jnilib
0x9c5dc000 - 0x9c5fafff libjava.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libjava.jnilib
0x9c605000 - 0x9c60dfff libverify.dylib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libverify.dylib
0x9c66e000 - 0x9c694fff libjpeg.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libjpeg.jnilib
0x9c6d6000 - 0x9c6e2fff libnet.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libnet.jnilib
0x9c6e6000 - 0x9c6ebfff libnio.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libnio.jnilib
0x9c6f1000 - 0x9c739fff libsuncmm.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libsuncmm.jnilib
0x9c742000 - 0x9c74ffff libzip.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libzip.jnilib
0x9fdbf000 - 0x9fe21fff libfontmanager.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libfontmanager.jnilib
0x9fe37000 - 0x9fe45fff liblaf.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/liblaf.jnilib
0x9fe4a000 - 0x9ffa6fff libawt.jnilib /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libawt.jnilib
=======================================================================================================So, what's up with that? Is anybody else testing this on a Mac with similar spec? having any such issues? Am i the only one left using a G4 iBook... probably
Date/Time: 2008-09-07 02:19:28.994 +0200
Report Version: 4
PID: 395
Thread: 12
Codes: KERN_INVALID_ADDRESS (0x0001) at 0xfffffff4
Thread 0:
Thread 1:
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12 Crashed:
0 libmt.so 0x0a5bf1e8 Tr::formatString(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 40
1 libmt.so 0x0a5bf2b0 Tr::TTransMidiAction::GetMidiString() + 28
2 libmt.so 0x0a619ea0 Java_com_bome_mt_jni_TTransMidiAction__1_1getMidiString + 40
13 <<00000000>> 0x0469c130 0 + 74039600
22 <<00000000>> 0x0458aab0 0 + 72919728
23 <<00000000>> 0x0458ae10 0 + 72920592
24 <<00000000>> 0x0458aab0 0 + 72919728
27 <<00000000>> 0x0458ae10 0 + 72920592
28 <<00000000>> 0x0458ae10 0 + 72920592
29 <<00000000>> 0x0458aab0 0 + 72919728
30 <<00000000>> 0x0476368c 0 + 74856076
31 <<00000000>> 0x04751ef4 0 + 74784500
32 <<00000000>> 0x0474c5a0 0 + 74761632
33 <<00000000>> 0x0468f698 0 + 73987736
34 <<00000000>> 0x047131dc 0 + 74527196
35 <<00000000>> 0x0475ea34 0 + 74836532
36 <<00000000>> 0x04757134 0 + 74805556
37 <<00000000>> 0x0468f638 0 + 73987640
38 <<00000000>> 0x04754430 0 + 74794032
39 <<00000000>> 0x04726f58 0 + 74608472
40 <<00000000>> 0x0471cb64 0 + 74566500
41 <<00000000>> 0x0458a930 0 + 72919344
43 <<00000000>> 0x0458aab0 0 + 72919728
44 <<00000000>> 0x0458aab0 0 + 72919728
45 <<00000000>> 0x04588164 0 + 72909156
46 libjvm.dylib 0x9c26bd38 jio_snprintf + 397640
47 libjvm.dylib 0x9c279444 JVM_StartThread + 2612
48 libjvm.dylib 0x9c279330 JVM_StartThread + 2336
49 libjvm.dylib 0x9c2792c0 JVM_StartThread + 2224
50 libjvm.dylib 0x9c27917c JVM_StartThread + 1900
51 libjvm.dylib 0x9c20418c JNI_CreateJavaVM_Impl + 48364
52 libSystem.B.dylib 0x9002bd08 _pthread_body + 96
Thread 13:
Thread 14:
Thread 15:
2 libmt.so 0x0a5cb568 bthread_cond_wait(bthread_cond_t*, int, int) + 408
3 libmt.so 0x0a5eacec Tr::TRuntimeDispatcher::Execute() + 84
4 libmt.so 0x0a5e3d88 Tr::TThread::run(void*) + 48
Thread 16:
5 <<00000000>> 0x0470245c 0 + 74458204
6 <<00000000>> 0x046db268 0 + 74297960
7 <<00000000>> 0x046daa00 0 + 74295808
Thread 17:
srr0: 0x000000000a5bf1e8 srr1: 0x000000000000f030 vrsave: 0x0000000000000000
cr: 0x48000204 xer: 0x0000000000000004 lr: 0x000000000a5bf2b0 ctr: 0x000000000a619e78
r0: 0x00000000f0e8c240 r1: 0x00000000f0e8c1e0 r2: 0x00000000a0001fac r3: 0x00000000f0e8c2cc
r4: 0x00000000018eec1c r5: 0x0000000000000000 r6: 0x00000000018eec00 r7: 0x00000000018eec1c
r8: 0x0000000070800003 r9: 0x0000000000000000 r10: 0x0000000026632b10 r11: 0x0000000000000000
r12: 0x0000000000000000 r13: 0x0000000000512010 r14: 0x000000000460cdfc r15: 0x000000000a619e78
r16: 0x00000000f0e8c350 r17: 0x000000002a804150 r18: 0x00000000f0e8c3a4 r19: 0x00000000f0e8c338
r20: 0x000000002a804348 r21: 0x000000002a804150 r22: 0x00000000000000b7 r23: 0x000000000000002e
r24: 0x0000000000000071 r25: 0x00000000265fcf20 r26: 0x0000000026ed3df0 r27: 0x0000000026cccda0
r28: 0x0000000026ccd3f0 r29: 0x00000000f0e8c2cc r30: 0x00000000f0e8c1e0 r31: 0x000000000a619e84
0xa5b7000 - 0xa67cfff libmt.so /Applications/Bome's Midi Translator.app/Contents/Resources/Java/libmt.so
