using mtpro on two computers?
twintip
2008-09-14 17:48:07
If I buy MTpro, will I be able to install it on my studio computer as well as my gigging laptop?
I will only use only one at a time - I prepare my live sets on my studio PC then transfer the SDHC card containing the live set to my gigging laptop.
ruediger
2008-09-15 10:20:46
Hi Twintip,
sure, if you use your laptop and your PC not at the same time, you can install it on both computers. Only if you use it at the same time, we will ask you to buy another license.
Rüdi
twintip
2008-09-15 19:18:28
thanks
i will use only one computer at a time
ruediger
2008-09-15 20:38:56
fine, then you need only one licence!
So, Happy translating :)
Rüdi
Masabasic
2010-01-19 04:42:49
glad I found this, thank you search function. I plan on performing on a laptop, but it will be much easier to program on the desktop with two monitors.
Thanks guys for already answering this!
akamed
2013-12-04 22:59:58
I was also asking myself about this question and found the answer here.
Thanks folks!
