Pro 1.7 Beta 1139
funkyant
2008-09-24 01:50:47
Firstly, I'm loving the multiport beta. It's been working superbly for me in a live situation.
Just letting the dev's know that I did have some glitches installing the virtual ports. Initially, with the default settings, everything was fine. But when I tried to use 4 virtual ports, the software could not open the ports. After a few restarts, the problem seemed to correct itself though.
If any more info is needed don't hesitate to ask. Thanks for the opportunity to test this beta.
System:
C2D E8500
2Gb DDR800
MOTU Microlite
MOTU 896HD
Win XP Pro SP3
Ableton Live 7.3
funkyant
2008-10-09 20:11:56
The beta has now expired :cry:
Is there another updated release I can get my hands on?
Thanks in advance.
2008-10-09 20:33:56
hi, there is a new version where you've downloaded the last inofficial beta.
Best,
newnumbertwo
2008-10-15 09:30:28
is this beta available to pro owners? or is it a closed beta? i would like to try it out.
2008-10-16 00:44:25
yes, this is a semi-open beta program. You need a MT Pro license and apply for it. In your case I could locate your license and I'll send you beta test information by PM.
