olafmol
2008-10-08 23:43:49
Hello,
i have purchased a Reloop Digital Jockey midi-controller, and so far am really liking it. I am using it together with Traktor 3. I also bought MT Pro to get the maximum out of my gear
One of the things i cannot do with the standard Traktor mapping is assigning a rotary controller to a different CC when pressing it down and turning. The Reloop has several rotaries that also act as push-buttons and send a note on/off when pressed down/released.
I have made some rules in MT Pro that enable me to send the rotary to a different CC when having the rotary pressed down and turning it, but i am wondering if they way i have implemented it is the best way:
Translator 2: eqlowleft
Options: stop=false
Incoming: MIDI 90 16 pp
if pp==0 then g0=0
if pp==127 then g0=127
Outgoing: MIDI 90 16 pp
Translator 3: eqlowleftturn
Options: stop=false
Incoming: MIDI B0 05 pp
Outgoing: MIDI B0 g0 pp
i have used CC 0 and CC 127 for testing purposes. I would like to know if this is the smartest way to implement this, or if there are better ways?
Cheers, Olaf
Options: stop=false
if pp==0 then g0=0
Options: stop=false
Cheers, Olaf
