red33mer
2008-11-03 19:47:51
is it possible to set multiple incoming messages as a trigger in one translator as you do with multiple outgoing messages (p.e. 90 4F 01 90 51 01)?
I could use a variable in the incoming trigger field (p.e. 90 pp 01) but lets say i want the action to be triggered by channel 79 and 81 only. I know that i could use and "if condition" and filter it but that means additional lines of code in the rules field. It would be much easier if i could set up two messages in the incoming field....
i tried but it isnt working so i wonder if i used wrong syntax or if its not implemented?
thank you
thank you
