mrsaxman29
2008-11-15 21:39:38
Is there a way (using variables or otherwise) to have an incoming Midi message trigger a translator across multiple Midi channels? I know you can enter variables for things like velocity, but can the same be done for channels?
My example specifically is to have either: B0 5A 7F or B1 5A 7F produce the same outgoing message.
Basically, I use my Nord Stage in a live looping scheme with Ableton Live with the help of MT to streamline the performance (a lot like the infamous kid beyond rig); however, the momentary pedal I use (which is plugged into the Rotor Speed jack of my Nord) transmits its Midi messages over 2 different midi channels depending on what panel is active in my Nord preset (the nord has 2 panels so that you can multiply split its instrument over various sections of the keyboard).
