note length control (fader/knob)?
fanboi
2008-12-02 13:27:21
yep. its me again.
i understand that you can use a timer to lenghten a note by setting a timer then sending note off from this timer, which is great because i recently got a drumpad controller that sends out note on then nearly instantly sending out note off again.
now, is there any way that i could perhaps lengthen this note by a nonfixed amount that i select via knob and/or fader instead of a fixed timer?
cause that would solve alot of headaches from me, alot indeed.
ruediger
2008-12-04 09:18:58
Hi fanboi,
you can set the Initial Delay of the timer with a knob. The only thing you have to do is to set a global variable with a knob. Then you use this global variable as the Initial Delay of the Timer.
Rüdi
fanboi
2008-12-04 18:22:33
ruediger wrote:Hi fanboi,
Rüdi
doh. why didnt i think of that?
ill give it a go and see what happens :)
