Keep presets made with demo in a bought version
barnabooze
2008-12-05 11:09:04
Hello!
I have been working extensively with a demo version of MTpro. I waited too long before buying it and now the demo is over. I want to buy the licensed version but I'm wondering if I can find back the presets I made with the demo version.
Barna
2008-12-06 16:25:12
Hi Barna,
yes, the file you created are compatible and do not expire. You should find them on your hard disk (e.g. in My Documents\Bome's Midi Translator). Better to make a back-up copy. Also, to be sure, you don't need to uninstall MT Trial before installing the full version. (the uninstaller usually does not delete user-created files, unless they are the same name as a preset file that shipped with MT Pro).
Hope that helps!
