AGT
2009-01-08 12:55:55
I'm trying out the Bome, and wanted to use it to map some Presets of Line6 Gearbox for my GuitarPort. The pretended version will be a footcontroller or a keyboard changing presets in Gearbox. I tried some things, now having Gearbox as Input and Output (controlling itself):
> I managed to translate a small midi message, such as activating the GATE pedal (clicking on it), and having Bome activating the WAH pedal through an outgoing message (got the codes by receiving it in Bome). In this cases, the Midi messages are quite small.
> This first step to tell you that things are communicating and working. Now, making the same thing but trying a Preset code it does not work. I tryed 2 simpler tests:
> Ingoing a pedal activation, and outgoing a preset change: does not work
> Ingoing a preset change, outgoing a pedal activation: does not work
The preset codes are quite big. Can this be the problem? Am I doing something wrong or is it a bug/limitation of the program?
For instance, one preset change Midi code is:
F0 00 01 0C 08 74 01 44 69 73 74 6F 72 74 69 6F 6E 2B 57 61 68 2B 52 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 21 00 7F 00 35 00
Cheers, and thanks!!!
