Problem with the usb midi hub input.
Asdor
2009-01-21 00:30:42
Hello! there's a problem using the translator classic.
I have a USB Midi hub 4x4 by Prodipe. When i select one of his 4 input channel on the translator, it say: Cannot open midi input device name_of_the_input" because it is already in use.
It only work if i select the input of my external audio card that is a Edirol UA-4FX.
I really need to use it with a device plugged on the usb midi hub..
Somebody can help me?
ruediger
2009-01-23 15:42:51
opening a MIDI port is exclusive. That means that another program has access to your MIDI input device. Close it and you will be able to open it in MT!
Best regards,
RĂ¼di
