Maddcow
2009-01-26 13:52:55
Hi all. I'm new to MT and am using it with Ableton Live 7.0.14 on a Mac. Here's what I'd like to do:
I'm using 5 different softsynths on 5 different tracks and want to arm individual tracks when certain patch changes are received, but then disarm those tracks when patch changes are received that utilize a different synth on another track.
Is it possible to configure MT to arm a certain track/s (via a pre-configured keystroke) when certain patch change numbers are received, but then disarm that track/s when other patch numbers are received that don't use that particular track/s? Also, I sometimes layer the synths by using 2 or more simultaneously and so there are times that I'd need to arm multiple tracks simultaneously too.
I know it's easy enough to arm a track when a certain patch number is received, but I'm not sure how I'd go about configuring MT to disarm the track when other patch numbers are received that don't use that track. I guess I'd need MT to retain variables that record the current state of each track and whether it should be armed/disarmed depending on the patch numbers being received? Live uses toggle state switching for track arming/disarming instead of separate On/Off states, and so I need a solution where I can't accidentally arm/disarm a track because the toggle state somehow gets messed up.
Here's a practical example:
Patch #01, #05, #06, #11 = Track 1 ON, tracks 2-5 OFF
Patch #02 = Tracks 2 & 3 ON, tracks 1,4 & 5 OFF
Patch #03, #19, #07 = Track 2 ON, tracks 1,3,4,5 OFF
So you can see that MT would have to arm/disarm tracks based on patch change recognition.......similar to having a database query, I guess, with On/Off toggle state commands being returned across all 5 tracks based on the patch number being received. BUT, MT would have to remember the state of each track i.e. whether it should currently be armed or disarmed, based on the previous patch change command.
Can anyone help?
Can anyone help?
