remotecontrol
2009-02-04 22:11:58
I have seen posts on cc to note already but Im not sure if the "twist" I want to add would change the entire sequence of things.
I want to have a potentiometer slide up and down specific Notes that make up a scale. The effect would be much like dragging your hand up all the black keys on a piano making a pentatonic scale.
Now...here is the twist: I want a separate note to trigger the actual hitting of the keys. So say my left hand uses the potentiometer to line up the notes and my right hand hit a button that hits the keys. "NOT" like a Gate function but the actual note on/off.
Now that I am thinking about it, the behavior would be similar to guitar hero. I guess the only difference from what I can tell is that on guitar hero it seems to be a simple rule that says "if left hand is on said key and right hand strokes pick at the same time then a preselected note is "gated" open" in my scenario any note could be chosen at any time by the potentiometer and the pick/key/button plays the note on/off
So what do ya think?
