X-Tempo Pok
BuleriaChk
2009-03-01 06:58:12
I am trying out the x-tempo pok, which is a footswitch/keyboard emulator, and am trying to trigger Battery 3 cells. Unfortunately, I think Battery 3 only accepte MIDI inputs, so I'm thinking I can assign the keys on the Pok to MIDI notes, and trigger the Battery 3 pads that way, using MT as the translator.
Am I correct in assuming this functionality is only available in MT Pro?
And, will it work with Battery 3 running as a VST within Live? Other VST's (e.g., to control patch changes in GR3?)
(FWIW, The other issue I am having with the X-Pol is an unacceptable delay when triggering events in Live - almost a half second. I'm working with T/S on this issue, but if it can't be resolved, the question may be moot..)
2009-03-04 17:45:44
as far as I can see, all your assumptions are correct. I can't guarantee that it'll work in any case, but in theory it should. Just try it with the trial version!
