Bomes/Ableton Midi Map
soul spectrum
2009-03-23 01:10:02
Is it possible to use Bomes Midi assignment WITH Live's own Midi Mapping assignments?
Ever since i use Bomes, Live's own Midi Mapping becomes un-accessible.
Do i need to somehow setup a rewire situation?
Any help is appreciated.
Boris
2009-03-31 21:59:26
You probably need to activate MIDI THRU in Midi Translator so that MIDI messages are passed on from your controller to Ableton. Make sure you use a virtual MIDI port to connect Midi Translator's MIDI OUT to Ableton's MIDI IN. Do not select your controller as MIDI IN in Ableton.
Aphid
2009-04-04 16:38:24
Also, in 1.7 there is a bug it seems whereby if you have a blank preset 'ticked' (activated) it will cancel out all Midi Thru messages.
Not sure if this is a bug or a feature. It'll pay to make known in the help file or here on the forums however. So hopefully people will search the forums if they also come across this issue.
Keywords: midi thru, ableton passthru, midi routing, virtual ports not working broken
2009-04-08 09:53:07
Hi Aphid,
thanks for the notification A blank preset shouldn't ever do anything, especially not cancel MIDI THRU. If I can reproduce it, I make sure it gets fixed for the next version. I'll send you a PM for details.
