kvitamin
2009-03-24 05:57:02
So let me break down the issue. I'm trying to control the playstart of a 2 bar loop in ableton so I can hit eight different buttons and each one will start from a different position within the loop (like button one would start at the begining, button two would be the following snare, button three would start on a hi-hat sound etc) . I've assigned a knob to control the clip's playstart so when you turn it, the start position moves down the clip from beginning to end.
In MT I've got:
Translator 1: press button one and it sets the knob's value to 0 (setting the playstart to the beginning)
Translator 2: press button two and it sets the knob's value to 16 (the next quarter note)
Translator 3: press button one and it triggers the loop
Translator 4: press button two and it triggers the loop again
This works well except the only problem is that when i toggle back and forth between button one and two, it triggers the loop before setting the value of the knob so it plays from the current playstart position, then moves the playstart to where I want.
Any thoughts on how I can make it always change the playstart position BEFORE triggering a clip? Can you force the order of the translators?
Thanks for the help,
In MT I've got:
