[resolved] Problem starting...reinstall this program OSX
timothyallan
2009-03-28 02:39:38
This is what I get with the latest 1.61 for OS X on 10.5.6
"Problem starting up Bomes Midi Translator. Please reinstall this program. [NullPointerException]"
I have downloaded and reinstalled multiple times, same thing.
Tim
2009-03-28 18:55:21
Oh, that doesn't sound good! Sorry for this problem.
- Is this the trial or full version?
And, to help us, can you launch the program from a terminal window?
1. Open terminal
2. Type
open -a /Applications/Bome\'s\ Midi\ Translator\ Pro.app
3. hit Enter to start MT in the Terminal
If there is any output on the Terminal, please copy/paste it here into the forum. That will greatly help us finding out what's going on!
Thanks a lot,
timothyallan
2009-03-28 21:31:11
Hi Florian,
This is the full version. I just did the terminal window thing, and I see the splash screen for a split second, and then the same error in a dialog box.
Unfortunately there is no output in the terminal window, it simply goes to a new line after the program executes :?
Im running on a Macbook Pro 2.4ghz and was able to use the first OSX bulids of Bomes versions without any drama.
2009-03-29 19:06:16
I've contacted you by PM to follow up with this problem.
vision
2009-04-29 02:40:43
Was a solution ever found for this? I'm running into the same error.
Things I've tried:
* Nothing shows in the console when ran the app from there.
* I've restarted my laptop.
* Tried starting with my midi-usb plugged in & not plugged in.
* Reinstalled multiple times, even deleting the Bome directory in my home folder.
* It worked once when I first started it entered my license key, but has yet to startup since.
timothyallan
2009-04-29 02:45:13
Nope, sorry. The Bomes crew was very, very helpful, but we never resolved it.
I told them I was going to wait for 10.5.7 to be released as I plan on reinstalling when it does... and then MT still didn't work, I would get back to them :)
vision
2009-04-29 07:40:10
w00t! i figured it out. \o/
so goto spotlight (or quicksilver) and type 'java preferences'. then make sure that j2se5.0 is the top most jre used - mine was set to 6. there were some changes between the versions that obviously makes things not backwards compatible.
anyway, this solved my problem, and i bet itll solve urs as well.
glhf
timothyallan
2009-04-29 07:44:03
Sure doesn't :)
Mine was set to 5 already. Rats.
vision
2009-04-29 07:51:43
jic, it's set to 5 32-bit and not 5 64-bit right?
timothyallan
2009-04-29 07:53:34
You sir, are a champ.
now she works :)
ruediger
2009-04-29 09:27:05
Hi vision,
many thanks to you for checking our this problem!!!
Cheers,
RĂ¼di
